Topic: Show value of "Field1" tag in Skin
Hi! I am using my own skin and I am trying to modify it so it does show the value of the "Field1" (User1) tag next to the %Title on the current deck.
I tried something like this:
<text size="23" align="left" weight="bold" format="%Field1"/>
But this does not work. I also tried "%user1", "%field1" etc. but none of these display the value of that tag.
Does anybody have an idea? Could it be that custom tags are not supported within Skins?
Thanks!
geposted Mon 08 Jul 19 @ 12:00 pm
using format and percent values are the old way
you now can use action and get_loaded_song
<text size="23" align="left" weight="bold" action="get_loaded_song Field1"/>
Ah, great! This works! Thank you!
