Topic: Description field in Script Editors
NicotuxHome userMember since 2014
Many descriptions of verbs in Pads Editor/Button editor do not wrap (anymore ? didn't notice before even while translating) and are not readable i.e.: all verbs in "flow" category and all but "set" in "variables" and "blink" and "param_1_x" and others in parameters
some other are working i.e. : "set" in variables and "color_mix" and "fade_out" in parameters
By the way thanks fot the fix the about non alpha verbs issue !
geposted Wed 10 Jul 19 @ 10:11 am
