Topic: I can't set pitch to 0.0 exatly
Hi guys , i have this strange problem . I can't set pitch slider to 0.0 exactly with my Numark Party Mix . I i put the slider on the middle it sets to +0.2 or -0.2 or something like that .Is there a way to fix the problem ? I thinked about a script when pitch is 0.50 (middle position i think) to set the slider to 0% but i'm not quite sure . Can someone help me ? Thanks !
geposted Thu 11 Jul 19 @ 9:36 pm
Use the keyboard shortcut Ctrl + * (character above the number 9 next to /)
The Numark PartyMix doesnt have any "click" center position, so the fader itself wont help you be dead accurate at zero pitch point. Neither it has some great resolution or a large fader length, so you could be near 0% only if you have selected some small pitch range like 6% or so.
Not many buttons on the controller available either to map one, so you will probably have to use a keyboard shortcut or a skin custom button mapped to do that if you are not using the default skin (double-click on the reset dot next to Pitch).
The action you need to use is .. pitch 100%
