Topic: New to virtual dj from numark cue
I have recently switched to virtual dj from numark cue one difference I can see so far that I’m missing is that if I load a song into a deck and change my mind therefore not playing and replace it with another the first song I loaded onto the deck use to drop down into another box at the bottom rather than going back into main library, if I then want that song again for later I have to search for it again is there anyway around this. Many thanks in advance
geposted Fri 26 Jul 19 @ 6:47 pm
Enable - showHorizontalSideList
Enable - saveUnplayedToSideList
Restart VDJ.
You will then have a sidelist panel at the bottom of the browser and if you eject a song from the deck or replace it without playing it will go to the sideilist automatically
hi good m
That sounds like what I’m after many thanks 👍🏼
