Topic: VDJ does not really exit
NicotuxHome userMember since 2014
Since v8150 I never saw VDJ exit cleanly
Even it seems to exit, no more icon, no more reference in task manager, restarting VDJ says already running
An old bad well known "waiting for network I/O" in request queue
debugger reports :
Le thread 0x10f0 s'est arrêté avec le code 0 (0x0).
'virtualdj8.exe' (Win32) : Déchargé 'C:\Windows\SysWOW64\FWPUCLNT.DLL'
Le thread 0x2198 s'est arrêté avec le code 1 (0x1).
Exception levée à 0x76BDFD62 (KernelBase.dll) dans virtualdj8.exe : 0x80010108: L’objet invoqué s’est déconnecté de ses clients.
which translate something like that
Thread 0x10f0 stopped with code 0 (0x0).
'virtualdj8.exe' (Win32) : Unloaded 'C:\Windows\SysWOW64\FWPUCLNT.DLL'
Exception raised at 0x76BDFD62 (KernelBase.dll) in virtualdj8.exe : 0x80010108: The object invoked has disconnected from its clients.
reported multiple times when we wait long enough
once more, have to go to ressource monitor to kill the process tree, task monitor does not display anything
when not debugging of course
[edited] VDJ 64bit seems not to be affected
Launching VDJ Debugger reports
Exception levée à 0x76BDFD62 (KernelBase.dll) dans virtualdj8.exe : 0x000006BA: Le serveur RPC n’est pas disponible.
IDelegateFolder: 6times
Exception levée à 0x76BDFD62 (KernelBase.dll) dans virtualdj8.exe : WinRT originate error - 0x80040155 : 'Échec de la recherche de l’inscription de proxy pour IID : {ADD8BA80-002B-11D0-8F0F-00C04FD7D062}.'.
translate like this:
Exception raised at 0x76BDFD62 (KernelBase.dll) dans virtualdj8.exe : 0x000006BA: RPC serveur not available
Exception raised at 0x76BDFD62 (KernelBase.dll) dans virtualdj8.exe : WinRT originate error - 0x80040155 : 'Failed to find proxy registration for IDD: {ADD8BA80-002B-11D0-8F0F-00C04FD7D062}.'.
geposted Sat 27 Jul 19 @ 11:09 am
Are you using any network drives/virtual drives with custom drivers or anything like that?
geposted Sat 27 Jul 19 @ 1:10 pm
May be consider something like that... No custom driver, but bad network most of the time.
I use WIFI/4G connection through an Android Phone plugged in USB - stock rom - for two raisons : SIM authentification to WIFI; in a way to keep the PC see network up even when one or both disapear; to prevent rescanning of devices everytime network fails & restart.
There is no cloud drive enable or any network drive but what VDJ is using if any.
The only one "Custom" driver can be Coolsoft MidiMapper which does raise error dialogs for years at every start of midi/devices scanning in VDJ 32bit - fixed for some time and comes back last year. VDJ 64bits does not have this issue and opens it correctly
geposted Sat 27 Jul 19 @ 3:26 pm
