user19956423PRO Subscriber
Member since 2019
(excuse me for my english, it's not my first language)
Hello, sometimes when I play a song the software doesn't play it properly, it sounds weird even though I played it multiple times before and it always sounded good.
I thought it was because my laptop was too old but I got the new macbook pro, but it keeps failing sometimes with random songs, so it's obviously a VirtualDJ bug, and it's embarrassing when it happens in the club. Do you know any way to fix it?
Thanks
geposted Sun 28 Jul 19 @ 1:38 am
PhantomDeejay
PRO Infinity
Senior staffMember since 2007
The term "doesn't play properly" doesn't really help us to understand your problem.
Can you try to explain it better ?
geposted Tue 30 Jul 19 @ 8:44 am
Member since 2019
I meant the software doesn't charge the song well, it starts breaking and also adds some delay to the song, it's very weird. And if I charge that song on the opposite channel, the song breaks even more, I have to choose a different song and then go back to the song I wanted to play previously to fix it.
I wish someone could help me with this issue because I really like Virtual DJ but now I have to pre listen to every song I'm playing in the club to check it doesn't crack and it's a bummer :/
geposted Sat 10 Aug 19 @ 7:06 pm
PhilW
PRO Infinity
Member since 2011
What controller are you using if any? Please post your audio configuration from VDJ.
What type of computer is it? OS? Processor, memory and other specs?
If you are using a controller, what happens when you use VDJ without it?
Does other software play the files correctly? What type of files are they?
geposted Sun 11 Aug 19 @ 4:25 pm
mitchiemasha
PRO Infinity
Member since 2008
Turn all your power save functions off.... Put the laptop into high performance mode. However you do that with a MAC, I don't know. Check the size of the ASIO buffer.
geposted Mon 12 Aug 19 @ 3:41 pm
mitchiemasha
PRO Infinity
Member since 2008
or what ever buffer they happen to use.
geposted Thu 15 Aug 19 @ 10:58 pm
