Topic: Latest Early build problem
I don't know how to explain it but theres a problem with my 3700's and the last few early access builds.
Heres a video showing the problem
geposted Sun 28 Jul 19 @ 6:11 pm
Can anyone confirm this??
Anyone??
I've not played out in a few weeks but have been installing all the EA builds. I then did a gig on Friday (July 26th) which was the first time in 3 weeks I used my NS7III and there was another update when I started up VDJ build 5181. Almost immediately tracks were drifting out of sync ,I did the same as you, same song on both decks, pressed play on both and one or both decks would go out of sync. With mine both decks start off at the correct speed, then slow down after a few seconds (possibly 16 beats in) before staying steady but sounding slower than it should, even pressing sync didn't keep them together long. The BPM's didn't show the drop in speed either. In the end I turned off the motors and it was fine for the rest of the night. I did another test on Sunday 28th with the current EA build 5182 and still the same thing. I tried everything to rectify it - except go back to a build which worked fine a few weeks back. I'll do another test tomorrow with a much earlier build
Thank you!!
That is exactly the same problem as far as I’m concerned.
Now I know I’m not going crazy!! I just downloaded the latest public build and they work fine.
I do have a DDJ SR if there’s a serious reason to upgrade the software but at this point in time I’m not gonna do.
And again Thanks for confirming there is an issue.
Can you check with 5185?
We have not been able to reproduce the issue yet, but it was likely related to the change that motorwheels use master tempo for small pitch bends.
This change has been reverted for now until we find out in which situations it causes this drift.
I'll be testing this out a little later today
I just got back into town so I’ll definitely get on this in a few hours.
Still not fixed on my end with the Denon 3700’s...
you beat me to it, same here too. Went back to builds 5003, 5044, 5045, 5046 and it's fine till build 5095 and the drifting begins. Just to Add - I've recalibrated the NS7III at the start (just to make sure)
Could you try again with 5186?
No Drifting with this build, cheers Adion
I just woke up so when I get back home I’ll give it go as well.
Fixed over here as well!!
Thank you team!!
