Topic: vj8 keeps crashing
Hi Guys
My VJ8 keeps crashing when i insert my external hard drive, which has my music stored on it.
But VJ8 opens when the drive is not inserted, but crashes when i insert it.
Any ideas, i have uninstalled VJ8 and re installed it, but the same thing happens.
I have a wedding on Saturday, so need VJ8 to work.....
geposted Thu 01 Aug 19 @ 11:28 am
What do you mean by "crashing" ? Does VirtualDJ close itself ? You get some freeze or a Windows "Stopped Working" window ?
If you plug your external HD without opening VirtualDJ, are you able to open and read files and folders with Explorer ?
geposted Thu 01 Aug 19 @ 11:48 am
Hi, It closes its self. But also, sometimes when i try to open VJ8 it takes ages to open, "saying its taking a long time to open the skin"
geposted Thu 01 Aug 19 @ 1:16 pm
Why does vdj stop working every time I plug in my external hard drive.
geposted Thu 19 Dec 19 @ 1:21 am
PhilWPRO InfinityMember since 2011
Does the external hard drive work without Virtual DJ?
When you say it stops working, what happens? Mac or PC?
geposted Thu 19 Dec 19 @ 6:29 pm
Hi I have the same problem. Virtual DJ runs fine, then when I plug the hard drive in. It crashes and closes and can’t re open the software ???? Has Any1 solved this problem yet
geposted Fri 27 Dec 19 @ 11:24 pm
