Topic: song not found
bogartPRO InfinityMember since 2004
Added a few new songs today. Having trouble with locating one.
When I search by the title, the song does not show. If I search by the
artist it appears. Using the My Library tool for added today, it finds the song.
If I use the * and then title, I will get results.
I have added to database, recursed etc. Still cannot just type in the title
and get results.
geposted Mon 05 Aug 19 @ 9:43 pm
geposted Mon 05 Aug 19 @ 10:26 pm
bogart wrote :
When I search by the title, the song does not show. If I search by the artist it appears
Perhaps the artist field is empty or incorrect ? Locate the track , open with Tag Editor and see if the Artist field is correctly filled.
Are you using tags or filenames to parse Artist/Title to VDJ DB fields ?
geposted Tue 06 Aug 19 @ 8:23 am
Did the add to database, recursed also. Checked the information for this and it is all correct.
Deleted it and tried again. Same results.
geposted Tue 06 Aug 19 @ 1:57 pm
Can you post a screenshot from Tag Editor with one of those tracks here, and exactly what you type in Search to find it ?
geposted Tue 06 Aug 19 @ 4:19 pm
Search by artist gives results, which is circled in red (Song is a remix)
Search by song does not show the remix one. It shows the original track.
Tagged shows how it is tagged.
geposted Tue 06 Aug 19 @ 7:21 pm
as you see in this image is .... search all local files check?
geposted Wed 07 Aug 19 @ 9:30 am
I do not see this anywhere. I have Build 5186
geposted Wed 07 Aug 19 @ 2:11 pm
Click the dot next to the search box it's all outlined in the manual page I posted above.
geposted Wed 07 Aug 19 @ 2:49 pm
Ok that is checked. Still no luck
geposted Wed 07 Aug 19 @ 4:04 pm
