After a recent update waveform display only works on mirrored wave option, default and horizontal scratch result in an empty display (screenshots are attached). Sound end everything else work without a problem, as it was also before the update. Any suggestions or a solution?
My system: MBP 15" Mid-2012 (Mojave v10.14.6)
Default wave (and scratch) - not working:
Mirrored wave - working:
geposted Tue 06 Aug 19 @ 8:08 pm
Very much the same for me, but the only wave showing in mine is Horizontal Scratch, the other two options are 'blank'. tried closing down, re-opening but no change so far. I can cope short term with horizontal, but not my preferred setting. Advise asap please.
geposted Mon 12 Aug 19 @ 7:14 pm
So you're also on a Mac running Mojave?
geposted Mon 12 Aug 19 @ 7:38 pm
Works absolutely fine on mine including Mojave 10.14.6. System specs below;
System Specs;
MacBook Pro 15” 2017, 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3 Memory, Radeon Pro 560 4096 MB, Intel HD Graphics 630 n1536 MB, macOS Mojave 10.14.6, 500gb SSD, external WD Passport Ultra 2Tb HD containing Music, Video & Karaoke databases and is formatted NTFS, I use the Paragon plugin with NTFS for Mac.
VirtualDJ 2018 b5186 and Denon MC6000 MkII Controller.
System Specs;
geposted Mon 12 Aug 19 @ 11:55 pm
