Hi All
When viewing track lists: Title, Artist, Genre, Length, Comment
All text in the columns is to the left hand side of the column.......except 'Length' which is to the right hand side of the column!
Can this be adjusted/altered to show the text to the left hand side of the column as is for all the other columns?
Thanks in advance
Thanks in advance
geposted Fri 09 Aug 19 @ 10:45 am
Length and bpm are right aligned, I don't think that can be changed but if it bothers you just shrink those columns down so they look centred.
geposted Fri 09 Aug 19 @ 11:30 am
Have done that but just wondered if there was a fix.
Thanks anyway
geposted Fri 09 Aug 19 @ 11:39 am
