Since installing the latest version I cannot access the Automix Type menu. When I click it just closes the menu. I use the default 2 deck skin and have tried different ones with no luck.
geposted Fri 09 Aug 19 @ 12:24 pm
no need for so many posts that stuff gets negative attention.
geposted Fri 09 Aug 19 @ 12:27 pm
I am running B5186 and I can access the auto mix type...
geposted Fri 09 Aug 19 @ 3:22 pm
Yes there is a bug with the sub menus in automix and karaoke :
When main page is in fullscreen and video is fullscreen and always on top on second display located right of main display without info or effect or tips panel, the sub menus pop up under the video on the second display
Capture without always on top to see the issue :
https://imgdb.net/6094
geposted Fri 09 Aug 19 @ 3:50 pm
Until we provide a fix, have File info window openef so that the submenu stays on primary screen
geposted Sat 10 Aug 19 @ 1:32 pm
