Topic: Missing History
djvjwpPRO InfinityMember since 2008
Hi,
I recently had to reset my laptop, before I did this I saved my virtual dj folder to an external hard drive.
When I re-installed virtual dj after resetting my laptop I added my original virtual dj folder to where it originally was in my documents folder after renaming the installed one of course..
The problem is vdj sees all my folders but it does not see my history which is in the virtual dj folder?
How can I solve this issue?
Your advice please would be appreciated.
geposted Sun 11 Aug 19 @ 10:47 am
Hi,
Problem solved, unistalled vdj, re-installed it, before opening up vdj I opened my documents folder where virtualdj folder is .
I then renamed the fresh installed virtualdj folder so the vdj would not use it then put my saved virtualdj folder into my documents folder then ran vdj and all was back as it should be.
hope this helps someone else out there.
geposted Sun 11 Aug 19 @ 12:07 pm
Hi all,
I’ve just opened VDJ for the first time in a fortnight and it appears to have lost all my history.
Any idea how I can retrieve it?
It’s a really useful reference.
geposted Tue 22 Feb 22 @ 3:33 pm
bogartPRO InfinityMember since 2004
Mine was also missing. Go to Write History and make sure it is checked to yes.
geposted Tue 22 Feb 22 @ 3:59 pm
