Topic: Automix Cue Points Not Working Properly...Maybe
A.eXe 1PRO InfinityMember since 2011
I'm trying to setup a small automix playlist so I can step away when needed. The problem I have is when I add a cue point to the part that I would like to fade out of one song and mix into another, in the POI editor I change the cue point to 'Automix Point', select "Mix 'FADE' Exit Point the fade out section doesn't change to that area. In fact no matter what 'Automix Point' or Automix type is selected none adjust to the cue point that I'd like to fade the song out with. What am I doing wrong?
geposted Mon 12 Aug 19 @ 12:13 am
