Topic: Problems after latest update. All computers
JOHN187PRO InfinityMember since 2012
Drive c is full.
CPU meter not working.
Vdj won't save any changes to music files in vdj.
geposted Mon 12 Aug 19 @ 1:14 pm
cpu meter now shows how hard the audio engine is working by default, if you wish to change back
settings cpuMeter change back to system.
other stuff you need to give more info
geposted Mon 12 Aug 19 @ 1:26 pm
JOHN187 wrote :
Drive c is full.
That you really need to get cleaned up - if not a lot of things won't work
geposted Mon 12 Aug 19 @ 1:52 pm
That's the problem. It's not full. It's only 20 percent used. The vdj pop up keeps coming up with that error and not saving tags or bpm.
geposted Wed 14 Aug 19 @ 1:18 am
[IMAGE2
Only happened since the last update. And it happened to both computers. ]
geposted Wed 14 Aug 19 @ 1:21 am
Check your vdj home folder, properties, have you the security permission to write?
geposted Wed 14 Aug 19 @ 5:46 am
Yes I have permission to write. All users full control. But the files say read only. I uncheck it. But as soon as I do and apply it goes back to read only. Both laptops are doing this. I was told as long as it thinks drive c is full it won't let me edit or tags,bpm. It thinks there's no room. But there seems to be no problem with drive c on either computer.
geposted Wed 14 Aug 19 @ 12:17 pm
Windows Defender latest update labeled VDJ as a threat and disabled all it properties. Only way to fix was to roll back to the earlier Windows Defender or disable it. Thanks everyone.
geposted Fri 16 Aug 19 @ 2:10 am
