Hello everyone I'm trying to setup my FX buttons I can change effect for FX 1 but 2 and 3 button I cannot change them...there empty? Probably a easy fix...new to this controller and looked everywhere for help.
geposted Sun 18 Aug 19 @ 2:53 am
Have you read how these buttons work depending on the Single /Multi FX layout ? http://www.virtualdj.com/manuals/hardware/denon/mc4000/layout/effects.html
For Multi FX layout, make sure the skin you use (if not the default) offers the ability to show FX slots 2 and 3
geposted Sun 18 Aug 19 @ 3:48 am
Thank you for the response is greatly appreciated I am not using the default skin I'm going to revert back to it and see if that's all my issues I have read the manual go in the skin that I'm presently using it doesn't allow me to change the effects 2 and 3.
geposted Sun 18 Aug 19 @ 3:32 pm
