Topic: Help with vdjscript
Hi, I have VDJ LE and a Pioneer Wego controller. Djing at the weekend and had issues with gain. Each time you load a song the gain is reset which is a pita. How can I set the gain to a certain level without it being reset ? Appreciate your help !
geposted Mon 19 Aug 19 @ 7:13 pm
Not script, just a option/setting
autoGain no
geposted Mon 19 Aug 19 @ 7:19 pm
autoGain no
great many thanks :)
geposted Mon 19 Aug 19 @ 8:03 pm
