Topic: Buying cdj-350 license
If i buy this license can i only use my 1 cdj-350 or the 2 cdj-350's that i have
geposted Thu 22 Aug 19 @ 8:38 am
You can use both.
Actually you "could" use up to 99 (if you had that many)
A controller license does not limit the amount of the same controllers you can connect/use. Only the model/make.
geposted Thu 22 Aug 19 @ 11:26 am
