Topic: Automix Editor Not Matching Beats.
Hey All!
So question here. I use automix because when I DJ I am also running doing a thousand other things going on at the bar/club.
When I used this a few months/years ago, I could go in and set up automix and decide the in and out of the crossfader and if i set match BPM's on it would slow down or speed up one song while the one it was going into would do the opposite. This doesn't seem to be the case anymore and the grid lines no longer match up unless the bpm's are the same to begin with. What is going on with this and how do I fix it?
geposted Sat 24 Aug 19 @ 8:53 pm
It depends both on your mix type and the difference in BPM's
For instance I have just tested using "Fade - remove intro/outro" and 4 sec automix length
Going from 74 BPM to 75 BPM get's beatmixed and the BPM gradually changes over the 4 sec
Going from 75 BPM to 82 BPM does not get beatmixed, so it's still 4 sec, but just a kump in BPM
Going from 72 BPM to 87 BPM get's beatmixed and the BPM gradually changes over the 4 sec
