Topic: Browser shows numbers left-aligned
Hi!
I don't know if this is the way it's meant to be, but my browser aligns the numbers to the left side when a track is focused... if it's not focused the numbers align to the right.
It is about one or two years like this already, but I never posted something and searched for a solution from time to time instead. I also tried to modify my browser in the xml, but didn't help.
Is this normal? And is there a way to leave it aligned to the right?
geposted Sun 25 Aug 19 @ 12:28 am
browserTextFit, anything but scroll
Yes, this helps indeed... but what if I want my text to scroll in order to see longer texts, but don't want my numbers to change their alignment? Is there no way such as modifying the browser in the xml?
Choose smart
This doesn't help either...
The shrinking is worse than everything else.
But I thank you anyway!
Can this be fixed by the dev-team?
