Topic: Barre de recherche de titres
Bonjour
Si je démarre virtual dj edition limited 8 seulement sur mon pc, j'ai bien la barre de recherche de titres de musique. Je peux taper un titre pour rechercher dans mon disque dur.
Mais quand je branche mon contrôleur dj kontrol4 (jb system) à l'ordinateur, cette barre de recherche disparaît.
Y'a til un paramètre ou un bouton à cocher pour voir cette barre de recherche s'afficher ??
Merci
geposted Wed 28 Aug 19 @ 5:13 pm
Please post in English, or use the French forum area.
The Limited Edition of VDJ is.........limited. Certain functions are missing or disabled.
If you want full functionality you need to buy a license.
geposted Wed 28 Aug 19 @ 5:16 pm
I will try to speak english.
Normally it's work with this version of virtual dj.
Because this research title toolbar appears when the portable computer is working.
But when we connect the controler djcontrol4 with the computer , the toolbar disappears.
May be there are buttons in the parameters to click on ?
geposted Wed 28 Aug 19 @ 5:30 pm
That is how it is made to work with the Limited Edition software, there is nothing you can change. The only thing you can do is buy a home plus licence or a full pro licence
geposted Wed 28 Aug 19 @ 6:39 pm
