Pls I have decided my hard drive to 3 ie c, e, and f. All have virtual dj database so after installing new Windows will my Virtual folder and my playlist lost? The documents are stored on the drive c and the Windows too on drive c
geposted Sun 01 Sep 19 @ 5:06 pm
Devided not decided
geposted Sun 01 Sep 19 @ 5:07 pm
DJ FESTIVAL138 wrote :
Devided not decided
Divided not devided….
geposted Mon 02 Sep 19 @ 12:10 am
probably due to having cracked software as he said on another thread
geposted Mon 02 Sep 19 @ 1:12 am
Not really keen on helping a user with cracked software, however, you can edit your database.xml file with a text editor and do a global search and replace to update all of the drive letters.
If that works for you, please purchase the software out of respect for the developer.
geposted Mon 02 Sep 19 @ 6:36 am
Yep, here....
https://www.virtualdj.com/forums/230519/VirtualDJ_Technical_Support/Virtual_Dj_crushes_when_I_connected_to_the_Internet_.html
It doesn't just crash, it also crushes!
geposted Mon 02 Sep 19 @ 6:40 am
