Hello
I have a mcx8000 denon everything works well except that the fx assignment buttons do not light up when activated despite doing their job, something similar happens with the sync, how can I fix this, thanks in advance
geposted Mon 02 Sep 19 @ 5:07 pm
Some functions in MXC8000 (and other controllers) may not work as in other software.
The FX Assign buttons do a temporary function (copy effects from one deck to the other), thats why they do not light up.
Please read unit's manual Nr.50 http://www.virtualdj.com/manuals/hardware/denon/mcx8000/layout/effects.html
The SYNC functionality in VirtualDJ is a temporary action and not a mode. Tracks get synchronized in BPM and Beat grid when pressed, but they do not lock up, so the SYNC button does not light up to indicate any mode.
geposted Mon 02 Sep 19 @ 5:47 pm
Thanks djdad another question is there any way to get the cue points to come out in the corresponding color as they do in serato, I know that I can change the color manually but it would be cumbersome and impractical to have to do it song by song
regards
regards
geposted Mon 16 Sep 19 @ 7:45 pm
settings nonColoredPoi different
geposted Mon 16 Sep 19 @ 7:52 pm
Ok I'll try it, thanks for your help
geposted Thu 19 Sep 19 @ 4:43 pm
