Topic: Bug?: Controller LoadSecurity
I want to creat a shortcut by SHift+S to switch "LoadSecurity" on and off.
So:
setting "loadSecurity" silent
works fine
But
setting "loadSecurity" on
or
setting "loadSecurity" off
doesn't work. Why? Is it a bug?
I also tested instead of "on/off", "0/1" and "yes/no". But it doesn't work, too.
Thank you
greetings
Patrick
geposted Thu 05 Sep 19 @ 8:58 am
try to add quotes around "on" and "off"
Why does the loadSecurity option need quotation marks if similar actions like autHeadphones (no/ onload/ always) do not need quotation marks?
Because on and off without quotation marks are recognized as booleans in script parameters.
...and in this case the “on” and “off” are the literal strings for the VDJ setting.
Okay, that makes sense. Thanks.
I want to build a button in my skin to switch between the "load-security" options "off" and "silent". The Button should be "on" when the option "silent" is active and "off" when "off" is active. But this feedback of the button doesn't work.
<define class="security" action=" setting 'loadSecurity' "off" ? setting 'loadSecurity' "silent" & on : setting 'loadSecurity' "off" & off" >
<size width="48" height="27"/>
<on x="1412" y="1196"/>
<off x="1294" y="1196"/>
<over x="1353" y="1196"/>
<text size="15" weight="bold" align="center" color="#aaaaaa" format="AUTO"/>
<textover size="15" weight="bold" align="center" color="white" format="AUTO"/>
<textselected size="15" weight="bold" align="center" color="white" format="AUTO"/>
</define>
Could somebody help me?
Greetings
Patrick
1- You try to use double quotes in double quoted string in your action
would be
action="setting 'loadSecurity' 'off' ? setting 'loadSecurity' 'silent' & on : setting 'loadSecurity' 'off' & off"
or
action="setting 'loadSecurity' 'silent' ? setting 'loadSecurity' 'off' : setting 'loadSecurity' 'silent' "
badly parameters passing prevent button to toggle as there is no param reported
2 -
param_equal "setting 'loadSecurity'" 'silent' ? setting 'loadSecurity' 'off' : setting 'loadSecurity' 'silent'
param_equal `setting 'loadSecurity'` 'silent' ? setting 'loadSecurity' 'off' : setting 'loadSecurity' 'silent'
would hilight the button but query is ignored
3.-
finally a workaround set a var ls and the setting in ONINIT to match the initial wanted state and
action=" toggle ls & var ls ? setting 'loadSecurity' 'silent' : setting 'loadSecurity' 'off' "
another working one : - really dont know why -
action="setting 'loadSecurity' 'silent' ? setting 'loadSecurity' 'off' & param_add 1 : setting 'loadSecurity' 'silent' "
