Ok now that SS supports OS2L does that mean we can now use the pads to control our lights from with in VDJ??
geposted Fri 06 Sep 19 @ 1:21 am
I dont think they implemented this part of OS2 yet. The Soundswitch is now using OS2L to get information of the played track , so this means that the Plugin is not necessary anymore.
geposted Fri 06 Sep 19 @ 3:42 am
Ok Thanks for the info.
I’ll email them again and see if they are working on a way to use VDJ pads to control lights from from with in VDJ.
I mean the loop rolls effect the lights so it can’t be far off I’d imagine, but then again I’m not a programmer Lmmfao
geposted Fri 06 Sep 19 @ 12:28 pm
It wont be hard to implement since the OS2L is now included.
BTW, since you are a SS user, how would you use your Pads with SS ? Map those to trigger Autoloops ? Turn on/off something ?
geposted Fri 06 Sep 19 @ 8:27 pm
Yeah me personally Id use them for auto loops or static looks.
geposted Fri 06 Sep 19 @ 10:44 pm
