Hi
Please am using a controller which is having air fx. What the air fx does it to decrease the volume so there is a way I can change the fx of the air?
Please help
Thanks.
Please help
Thanks.
geposted Fri 06 Sep 19 @ 2:44 pm
Or nothing like that?
geposted Sat 07 Sep 19 @ 2:58 pm
What is the make and model of this controller?
geposted Sat 07 Sep 19 @ 3:08 pm
Hercules
Dj control Jogvision
geposted Sat 07 Sep 19 @ 5:44 pm
Looking at the default mapping, all the air fx does is turn the filter on or off. It shouldn't affect the volume unless you've either remapped it or the filter is active (not in the centre).
geposted Sat 07 Sep 19 @ 5:51 pm
I was asking for how to change from filter to maybe cut or backspin ect
geposted Mon 09 Sep 19 @ 8:27 pm
