I love the default skin but there are a few things I would like to change.
I want the left track on the top half of the display.
i want the right track on the bottom half of the display.
I like simple blue or red displays in amplitude.
I would also like the beat detection dots to be bigger.
Also, what do the "S D R" buttons do on the tracks display. It's really weird.
I would like the LOOP functions to be easier. Like to toggle a single button for 1/4, 1/2, 1,2,4,8 beats.
Is this stuff possible?
Cheers :)
Cheers :)
geposted Thu 12 Sep 19 @ 11:21 am
In "settings" page "Interface" folder you have a link top right of the preview image to edit selected skin
https://www.virtualdj.com/wiki/Modify%20a%20Skin.html
Good luck
Good luck
geposted Thu 12 Sep 19 @ 11:30 am
All this stuff is possible if you want to try to modify the skin.
It's not the easiest thing to do, but it's not hard either.
S,D,R:
Save, Default, Recall
They control the zoom of the waveform display
S,D,R:
geposted Thu 12 Sep 19 @ 11:31 am
jasonbullen wrote :
It's really weird
It's not weird - it's in the manual. https://www.virtualdj.com/manuals/virtualdj/index.html
Before you attempt to mess with the default skin, take a look at the already available skins that are based on the default one. There are also lots of skins with their own unique design which you might find better than the default one.
Finally, you can even build your own skin by using djdad's Skin Builder. It's actually a skin itself, but it allows you to choose what you want, move it around and then save it.
geposted Thu 12 Sep 19 @ 4:43 pm
