Topic: DDJ-400
Hello! FX SELECT doesn’t change the applied effect. What can I do? Thanks.
geposted Mon 16 Sep 19 @ 5:00 pm
Where is the ASSIGN knob (below the FX select) set to ? If set to a Deck 1 or 2 , you should see the selected Effect in Deck 1 or 2 FX section of skin. If set to Master, you need to have the MASTER mixer panel visible to see the selection.
