Topic: Automix Editor customizations disappeared
doug9474ControlleristMember since 2019
I edited the transition from song A to song B. Then that edit disappeared. I'm not sure if it was because I moved one song, then moved the other. They still ended up in the same order relative to each other.
Why does virtualDJ get rid of my Automix Editor customizations?
I am using VirtualDJ 8.3
Thanks,
Doug
geposted Wed 18 Sep 19 @ 5:28 pm
NicotuxHome userMember since 2014
You are right, it's because you moved one after the other. at every move track loosed both transitions.
If they are finally end in the same relative order you better had to move them both at a time
This way only initial and final transitions are lost
just select both or more with shift+click and move the block
geposted Thu 19 Sep 19 @ 1:04 am
Well that sucks.
Thanks though.
geposted Thu 19 Sep 19 @ 7:08 am
The transition just randomly came back the next day. Second time that happened, so I'm thinking it is a bug.
geposted Thu 19 Sep 19 @ 2:26 pm
