Topic: Change Decks on DDJ SB3
DJ TUUTControlleristMember since 2016
Hello,
I just bought the Pioneer DDJ-SB3 with a Virtual DJ Home Plus license. While playing around i noticed that the buttons to swap between deck 1 & 3 and 2 & 4 are not working at all. I have the 4 deck layout selected and all the latest updates of both controller and VDJ downloaded. Any solutions? Might be something with the mapping? (i'm using factory default)
geposted Wed 18 Sep 19 @ 8:55 pm
I face the same problem when i select the audio output as anything other than the SB-3 sound card. The problem goes away when I select the SB-3 soundcard channels as master and headphone (VDJ restart required after applying settings).
geposted Sun 22 Sep 19 @ 9:51 pm
