I cant use my Controller and I have the pro-Account
geposted Fri 20 Sep 19 @ 11:44 am
What Controller?,Have You logged into VDJ?, Are the drivers installed?, Give us a clue
geposted Fri 20 Sep 19 @ 11:51 am
Oh well that narrows it right down. That’s very descriptive.
What controller? What’s it not doing?
all the drivers are installed and I have a Traktor Kontrol s2 and I have logged into my account as well plus I have a huge party tonight. before this update, I could easily plugin and it'll start right up and go. but not no more
geposted Fri 20 Sep 19 @ 2:10 pm
USB cable? Try a different USB port?
Is it lighting up? Showing as connected in settings? Any sound coming out?
What troubleshooting have you done?
geposted Fri 20 Sep 19 @ 2:27 pm
USB cable? Yes i have different ones
Try a different USB port? i have tried all of them
Is it lighting up? every once in awhile it'll try to blink on
Showing as connected in settings? nope no device found to connect to
Any sound coming out? no sound or lighting activity at all
What troubleshooting have you done? everything possible to troubleshoot it. be fore this update everything was fine I could plugin and it'll start right up no problem
geposted Fri 20 Sep 19 @ 2:33 pm
Is it S2 or S2MK2 ?
In your Accounts stats, it appears that you have connected a MK2, but in your Audio setup seems like you were trying the S2 ASIO drivers ??
Can you post screenshots here of your AUDIO tab and CONTROLLERS tab of VDJ Settings ?
geposted Fri 20 Sep 19 @ 2:36 pm
Go back to the last build and see if it works...
djdad wrote :
Is it S2 or S2MK2 ?
Its a tracktor Kontrol s2 MK2 which driver do i need to install?
geposted Fri 20 Sep 19 @ 2:40 pm
if you mean install the older version of V8 i did that and it did the same thing
geposted Fri 20 Sep 19 @ 2:41 pm
Sure i candjdad wrote :
Is it S2 or S2MK2 ?
geposted Fri 20 Sep 19 @ 2:42 pm
geposted Fri 20 Sep 19 @ 2:51 pm
Is it S2 or S2MK2 ?
geposted Fri 20 Sep 19 @ 2:52 pm
geposted Fri 20 Sep 19 @ 2:55 pm
geposted Fri 20 Sep 19 @ 3:04 pm
Mister_Rece wrote :
i have changed ports and everything
geposted Fri 20 Sep 19 @ 3:05 pm
geposted Fri 20 Sep 19 @ 3:09 pm
In the same NI page for Downloads, search for and install "Controller Editor 2.2.5 Windows 7 and above"
After that, restart your computer and see if its working now.
If still not working, you may have to re-install Traktor. IF not mistaken it also installs some Service that is required to run in the background (which is automatically started when your computer starts), cant recall its name though. For some devices this is required for proper functionality.
BTW, have you changed anything on your computer recently ? Was it working before on the same computer ?
geposted Fri 20 Sep 19 @ 3:58 pm
[quote=djdad]In the same NI page for Downloads, search for and install "Controller Editor 2.2.5 Windows 7 and above"
After that, restart your computer and see if its working now. thanks ill try it out
If still not working, you may have to re-install Traktor. IF not mistaken it also installs some Service that is required to run in the background (which is automatically started when your computer starts), cant recall its name though. For some devices this is required for proper functionality. (how to re--install traktor kontrol S2 MK2)
BTW, have you changed anything on your computer recently ? nope
Was it working before on the same computer ?[ Yes i was but it never had anything about asio either
geposted Fri 20 Sep 19 @ 5:24 pm
I said Traktor, the software that comes with your controller
geposted Fri 20 Sep 19 @ 5:30 pm
