Topic: New update with old vdj7 skin problem
I have just updated to the new version plus also went to 64bit.
I have always used the old vdj7 skin with no problems but when i use it with new version my cpu usage goes way up and everything lags.
When i switch to new skin everything is fine cpu usage comes down.
geposted Sun 22 Sep 19 @ 4:18 pm
It seems perfectly fine here. The VDJ 7 2 deck skin, with audio tracks playing, shows around 1% CPU.
Give us some info on your computer...
geposted Sun 22 Sep 19 @ 4:30 pm
Problem fixed.
A quick download of vdj7 plus the new 64 bit 2020 version then a uninstall and reinstall and there we go.
No more lag and cpu usage does not go sky high.
geposted Sun 22 Sep 19 @ 5:02 pm
