Maybe I touched a (wrong) button, but when I got the 2020 update and chosen the "Pro" lay-out, I loaded a song in deck 2 and start playing. Then I loaded a second song in deck 1 and I suddenly see the BPM/Pitch on Deck 1 changing to meet the BPM of Deck 2?
But.. maybe I did touched something... I have to check all other settings to see if they are the same as before the update...
I have disabled the "Auto bpm match" years ago and can not remember I used a button after the update to enable this again?
geposted Thu 26 Sep 19 @ 6:26 am
We had the same problem.
Just click at "SYNC" and disable Auto Match BPM (and the other entries)
geposted Sun 03 Nov 19 @ 10:16 pm
Can also turn this on/off in the deck options
https://www.virtualdj.com/manuals/virtualdj/interface/decks/deckbasics.html (#6 at Essential/Pro/Performance)
geposted Sun 03 Nov 19 @ 11:06 pm
