I cant run exclusive mode with native ASIO for my Aune X1S DAC. I enabled exlusive mode in options but i hear sounds from communicator, and sites.So its not exclusive mode.My native sampling rate is 384000hz and thats is set during dj set.Any advice from support?
geposted Thu 26 Sep 19 @ 11:18 pm
The exclusiveMode setting is used when using WASAPI driver, when using ASIO it will depend on the ASIO driver what happens with other programs audio.
Also I would recommend to use 44100 or 48000 for samplerate instead.
geposted Fri 27 Sep 19 @ 7:28 am
