Topic: Previous version
Is there a way to find out what version I was using before installing 2020. It has crashed on me 3 times. I tried changing font size and auto mix and another simple function. The last version I had worked perfectly but was not the last version of 8 as it did similar crashes. Simply put I need to remove 2020 and go back to the exact version that worked great for me and zero crashes. Or is there a button I can click to go back to the working version.
geposted Fri 27 Sep 19 @ 4:56 am
jucenicPRO InfinityMember since 2012
Go to download on your computer and you will find the last version overthere
geposted Fri 27 Sep 19 @ 5:33 am
GianVJPRO InfinityMember since 2012
geposted Fri 27 Sep 19 @ 6:35 am
Thank You so much
geposted Sat 28 Sep 19 @ 3:55 am
