How can I use the built in effects of the DDJ 1000 instead of the VDJ effects?
geposted Fri 27 Sep 19 @ 11:12 pm
you can't they turn off when software is connected.
geposted Fri 27 Sep 19 @ 11:30 pm
There is a way. I noticed when I switch to the Mic Channel the default hardware Beat FX worked.
I am waiting for an answer on how from VDJ.
geposted Fri 04 Oct 19 @ 1:52 pm
Please read: https://virtualdj.com/manuals/hardware/pioneer/ddj1000/layout/mixer.html#effects
Particularly the section in bold:
The MIC input is an ANALOG source. That's why DDJ-1000 uses "hardware" effects on it.
PS: When the BEAT FX SELECT switch is on MST (master) the effects can be hardware or software, depending on whether or not an analog source is mixed among with the digital ones.
That's how Pioneer designed the firmware of the device and VirtualDJ can do nothing to change it.
Quote :
As of Firmware 1.05 released in June 2018 from Pioneer, hardware effects are always applied on analog sources, while software effects are always applied on digital sources.
geposted Fri 04 Oct 19 @ 5:49 pm
