The key matching is cool, but I don't want to play my entire set in one key. I already use the camelot system to mix.
The upgrade to 2020 just ruined my set, because when I zeroed my BPM/speed (pitch) for a track the key changed. Previously I had this locked, but the upgrade ignored my settings. I looked in options but cannot find how to re-enable it.
How do I key lock my tracks, so the key is as-per the original track on load and when I change pitch (speed) the key is locked?
geposted Fri 27 Sep 19 @ 11:12 pm
master tempo is the setting you want
geposted Fri 27 Sep 19 @ 11:28 pm
Perfect thanks :)
geposted Fri 27 Sep 19 @ 11:37 pm
Did the master tempo fix the upgrade issue? I noticed the same problem and it messed up my mix as well...
geposted Sat 26 Oct 19 @ 10:06 pm
