Video cropping does not work the same in 32bit and 64bit
Transparent with black shapes are working well on 64bit, does not display video in 32bit, only the shape
Transparent white shapes are working well in 32 bit with a side effect in videoSkins
32bit version https://imgdb.net/6851
64bit version https://imgdb.net/6852
Maybe the colors are not the good ones, mask transition was using red black white
Note the "cover" plugin does not take care of position stored by 32bit version and defaults to fullscreen
In a video skin, as the breakline does not seem to work, maybe was not intend to ^^
version with a transparent image with black shapes background is black
with transparent image with white shapes , backgroung shows image with white shapes as a background
whatever the breakline and breaklineV are
use <background> to workaround
Finally everything was workaroundable in some ways - control pads, pressure sliders, cropping, background...
geposted Sat 28 Sep 19 @ 5:22 am
