I've deleted a large number of duplicates from my hard drive. I'm now finding these ghost files in my search. How do I get rid of them please?
geposted Mon 30 Sep 19 @ 11:38 pm
Browser options -> Database -> Remove missing files from search DB
tiny circle in the bottom left missing part of your pic
may take a time depending on the size of the database
as it seems you are using My Library extension:
you may also open another folder with tracks before you go back to current one again in a way to clear My Library filter folders cache
after what " My Library/Database/Tools/File Missing " filter folder must be empty
geposted Tue 01 Oct 19 @ 12:57 am
Thank you. I will try that out and report back.
geposted Sat 12 Oct 19 @ 3:40 pm
Thanks again. Super helpful. That worked. All the best.
geposted Sun 13 Oct 19 @ 2:45 am
