Topic: Unloading decks
Hi, I have just installed the latest update and have found that I can no longer remove songs from decks by right clicking on the play pause button. What has changed? How do I reset that function?
geposted Tue 01 Oct 19 @ 6:51 am
Use the eject button....
geposted Tue 01 Oct 19 @ 6:58 am
On Pro and Performance variations, there is an unload tab. If you are using a different one, you could program a keyboard shortcut, or use another skin that you like, that has that function.
geposted Tue 01 Oct 19 @ 8:07 am
Ok, thankyou I found it. :)
geposted Tue 01 Oct 19 @ 9:55 pm
