VDJ 2020 has been frozen several times with me so far. VDJ freezes after a while, if I download the covers for all my files by batch or if I scan the whole hard disk. As long as I'm still working in the player at the same time, it seems to work. I let VDJ only scan and after a while click on any button in the program, then hangs VDJ. I arrive with several hundreds of thousands of songs.
Thats in the Log:
--- 2019/07/08 - 20:52 (5046)
[20:52] Thread tagEngine freezed.
--- 2019/07/09 - 21:06 (5046)
[21:06] Thread tagEngine freezed.
--- 2019/07/09 - 21:08 (5046)
[21:08] Thread tagEngine freezed.
--- 2019/07/21 - 17:43 (5046)
[17:43] Thread tagEngine freezed.
--- 2019/07/26 - 14:57 (5046)
[14:57] Thread tagEngine freezed.
--- 2019/09/30 - 22:11 (5186)
Thats in the Log:
geposted Thu 03 Oct 19 @ 12:12 am
Could be a bad file, so would help u and us if you could spot this file (or more)
The only way is to split the analyze in smaller parts, so a long process for you unfortunately.
geposted Thu 03 Oct 19 @ 4:12 am
It can not be a broken file. Since this problem only ever occurs when I do nothing in the VDJ. Respectively, it appears on the cover download. My files are all ok. I scanned the entire hard drive without any problems or crashes.
I play music in VDJ while I scan, then everything runs smoothly. Only when VDJ is in sleep mode, and I just let it download for a while, and then something clicks, then it hangs itself away.
For example:
- I play musik and download the Covers per Batch. No problem. It works fine.
- Then I stop the music and do nothing on the PC, just let the covers download for 2 hours. Now I want to press any button in VDJ. Then Freezed VDJ.
geposted Thu 03 Oct 19 @ 10:04 pm
