Topic: Karaoke Playlist
Hi All,
My wife is a singer and sometimes uses karaoke backing tracks. I want to know is it possible to create a playlist of Karaoke tracks with their keys adjusted. I know the system saves the karaoke history with the key change, but she would like to organize her music with the key changes.
Is this possible?
Thanks.
geposted Thu 03 Oct 19 @ 4:57 am
Yes & No:
When the karaoke playlist is created, as well as history, Both singer name and key change are saved.
The problem are
- you can't save karaoke list
- you can't Load a playlist in karaoke sidelist with a right click "Load in .."
- you can't drag & drop playlist to karaoke sidelist
if you simply rename the Playlist -> Karaoke file to any other name it becomes a simple playlist.
You can load it by drag & drop to the Karaoke ICON bottom of the sideview
other solution :
browse and select the playlist; all the files display
You can drag & drop multiple files to karaoke sidelist, i.e. all with ctrl A + drag&drop
in both cases key changes and singers' names are restored
other solution :
I think this solution will work for now. Thanks.
