Topic: SpecialBalance.dll
SpecialBalance.dll plug in is not compatible with 8.4 ? 2020 / this plug in is reqired for songs that are set to left or right only and to remove the voice ! any idea?
Tested Stereochannel but as this is an EXE File, when doubleclicking it says "Virtualdj installation not found"
geposted Fri 04 Oct 19 @ 1:06 pm
geposted Fri 04 Oct 19 @ 1:10 pm
is there any stereochannel.dll to add to plugins folder ? when I doubleclick exe file it says Virtualdj installation not found
geposted Fri 04 Oct 19 @ 1:46 pm
open the exe as a zip file and you can access the dll without going the installer route
geposted Fri 04 Oct 19 @ 1:50 pm
thanks a lot!! I am tryin to find the way right clicking file and "open with" but is not available / I am unable to open as ZIP
I actually added it to a new zip file, changed extension and not working for me :( I may be doing something wrong.
geposted Fri 04 Oct 19 @ 1:56 pm
I use 7zip that can open as an archive
geposted Fri 04 Oct 19 @ 2:00 pm
Have you ever been told that you are a MASTER!!!!! thanks a lot.. that made the trick!!! AWESOME HELP!!
geposted Fri 04 Oct 19 @ 2:07 pm
One more quick question ... I was able to install dll fine now.. howvere when testing in a karaoke song that is set voice to right ... I cannot remove voice at all / even swithching between left or right !!! any idea?
The *.ini file from previous similar plug in SpecialBallance.dll was similar to
[AutoParams]
String Status 15=Output Stereo | Level Channels: Left 100 /Right 100
Slider Channel Left Level 0=2048
Slider Channel Right Level 1=2222
Button Output Mode 5=0
I am sharing this as you are the master of the masters on plugins so this information may help you better than me
geposted Fri 04 Oct 19 @ 2:25 pm
