Any way to have the comments show on the decks, as in VDJ8?
geposted Fri 04 Oct 19 @ 5:49 pm
Block Skin has that option...
geposted Fri 04 Oct 19 @ 11:11 pm
Yes, also the skin by Fruit. Just would like to use the new pro skin.
geposted Sat 05 Oct 19 @ 1:24 pm
Should be fairly easy to add...
Here we go - replaced the 'featuring' field with the 'comment' field.
OK spacing could be better, but the info is there.
geposted Sat 05 Oct 19 @ 1:42 pm
Thanks, but I really am not good at that sort of stuff.
geposted Sat 05 Oct 19 @ 1:43 pm
Groovin:
I cannot seem to find featuring field.
I tried to modify skin.
I open the skin and clicked edit. According to what is shows
we are supposed to click save and export full skin.
I do not get this option.
Can you please direct me?
geposted Sun 06 Oct 19 @ 3:11 pm
This is the wrong place to go into detail. Drop me a PM and I'll take you through it.
geposted Sun 06 Oct 19 @ 3:27 pm
