Topic: VirtualDJ is Already Running.....
It is not running, and task manager does not have it running. It was actually closed awhile ago, over an hour. What's my next step?
geposted Sat 05 Oct 19 @ 5:32 am
In the case you run windows ...:
Kill remaining task - mainly waiting for network answer forever - from "Resource monitor"
Open Resources Monitor
i.e. from Task manager, tab "Performance"
bottom right : open resources monitor
or by "Start Menu" in "Windows Administrative Tools" -> "Resource Monitor."
or typing resmon.exe /res
in Resource Monitor:
tab CPU
sort by processes in reverse order by clicking column "processes"
scroll down to virtualdj*
right click virtualdj* and select "End process tree"
if that fails select "End process"
I have had the same problem, try to reset settings.xml file (save a copy as backup first ;) and start over with a clean program.
Then do one tweak at a time and restart vdj and you will see what will cause the problem.
