Topic: Ns6 II cross fader problem
My cross fader controls the VDJ one on the screen but it makes no difference to the audio output.Both channels remain audible.
geposted Sat 05 Oct 19 @ 11:09 am
Have you got the crossfader assign switches set correctly?
In the app settings?
They are correct on the controller
Ok, got to test the easiest thing first, next easiest, perhaps you have the setting crossfaderDisable switched on?
Next easiest, is the software crossfader assigns following the hardware?
If not that then a pic of your audio config please,
Thanks mate.Seemed to get it working.All I did was change from performance to pro.
