Topic: Script question
I have the ddj1000 and have the below script to unload a track from decks 1 or 2.
'action_deck 1 ? deck 1 unload : deck 2 unload'
Since this is conditional statement with the 2 decks, I'm not sure how to expand this to decks 3 and 4. How can I get the same button to unload decks 3 and 4 if those are the selected deck on the corresponding side?
TIA
geposted Sun 06 Oct 19 @ 8:45 pm
why don't you just use 'unload' since that will automatically be applied on the deck it is called from?
Adion is spot on there, but since you're asking how to multi query
You add a new query to the false reply of the first query
action_deck 1 ? deck 1 unload : action_deck 2 ? deck 2 unload : action_deck 3 ? deck 3 unload : deck 4 unload
The issue with 'unload' when I originally set this up was that I am using a push of the browser knob. Since there was no left or right brower, it didnt unload the track on the correct deck, which I why locodog gave me the query script.
I will try both again when I am not at a gig.
Thanks!
Browser Encoders in DDJ-1000 send "global" values when turned clockwise/counter clockwise
However, pushing encoders down sends local (per deck) values.
So, for DDJ-1000 change the mapping to:
browser_window 'folders' ? browser_window 'songs' : holding ? unload : load" />
I'm not sure why this is, but none of the above suggestions work. In all cases it only works for deck 1, nothing else.
I also noticed the browser_scroll works for decks 1-3, not 4. It all seems odd, any thoughts as to why?
bump
