Topic: Shader downloads
What are the steps you need to take to be able to load a ton of shaders to multiple computers without having to deal with the nightmare of having to download them individually on each computer? Is there a way to download them all to one computer then copy the folder to other computers?
geposted Tue 08 Oct 19 @ 5:54 am
Yes. Download them all to one computer, then copy the folder to the other computers.
you forgot the step where you have to have the computer online, sit there and having it playing and on autochange and then constantly click Add when the pop up window says it wasn't installed would you like to install...
over
and over
and over
and over
again...
depending on how many shaders you have installed.. this could take a while. and if you have both the 64bit and 32bit versions of VDJ 2020 installed then you have to it for both versions.
