I have recently upgraded VDJ with a Denon MC6000 MkII. Was all working fine before the update but since the update everything works fine (buttons, sliders etc) and all LED's work as though the music is playing but I cannot get any output from the speakers. I have update the firmware. Has anyone else had similar issues or is there anything I need to check/do as part of the upgrade
geposted Wed 09 Oct 19 @ 12:42 am
have you checked to see if the sound config got changed some how?
geposted Wed 09 Oct 19 @ 12:50 am
Mac or PC?
I'm on a Mac with the MC6000MkII and no problems.
If you're on a PC do you have the current Denon driver installed?
A screenshot of your audio settings would be helpful.
geposted Wed 09 Oct 19 @ 1:44 am
