Hi
I've just upgraded to VDJ 2020, and I've notice and odd problems with the Denon MC6000 mk2 mapping.
The FX1 knob change the effect rather than effect slider
The FX2 button activates the FX1 effect
The FX3 button has no effect
Is there an updated mapping anywhere? Or can I remap these?
Thanks
Adam
Thanks
Adam
geposted Wed 09 Oct 19 @ 9:17 pm
Use SHIFT+ BEAT TAP to toggle between Single and Multi FX modes.
Read here how the FX buttons and knobs work in each mode http://www.virtualdj.com/manuals/hardware/denon/mc6000mkii/layout/effects.html
Note that the Essentials skin layout does not support Multi FX view, so if you want 3 FX slots, you will need to use the Pro or Performance layouts of the default skin or some other custom skin which supports Single+Multi FX modes.
geposted Wed 09 Oct 19 @ 11:53 pm
